Pretty sure the recommended is a 950CCA for a TD5 so i would guess the same for you.
G-day lads. Can anyone recommend a good battery for my truck?
I'm hoping that the right answer to that question is a Supercharge Allrounder MRV70 because I just fitted one in my Defender.If you can wait 4 or 5 years, i may be able to confirm that.
Supercharge Batteries - Car Batteries, Maintenance, Expanded Grid Technology
I bought from the local servo and he says he sells a lot to boat owners and that people seem happy with them.
They seem to be a lot heavier than similar size batteries. I hope that is a good thing.
Others have said good things here about that battery in the past.
Yellow or Blue Top Optima. I've got a Blue Top that is unkillable. Recharges quickly, can withstand heavy drain, highly vibration resistant, can be mounted in any orientation, no leaks or maintenance, etc, etc. Only downside is cost, but mine has paid for itself many times over in being able to sustain heavy cranking or deep draw. And it'll punch a lot harder than its specs suggest based on my experience.
AGM Deep Cycle Battery, Batteries - Optima Yellow Top
I'll never go back to a wet cell...
DiscoClax
'94 D1 3dr Aegean Blue - 300ci stroker RV8, 4HP24 & Compushift, usual bar-work, various APT gear, 235/85 M/Ts, 3deg arms, Detroit lockers, $$$$, etc.
'08 RRS TDV8 Rimini Red - 285/60R18 Falken AT3Ws, Rock slider-steps, APT full under-protection, Mitch Hitch, Tradesman rack, Traxide DBS, Gap IID
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
You should be able to pick up a Century MarinePro 720 for less than $200 from BatteryWorld. Good solid performer in an N70 (12") case that can take a hiding with vibrations and pretty good at recovering from deep drawdown.
Its all I use in the 'fender and flotilla of boats I watch over!!!
S
+1 for the Supercharge battery. I installed an NS70 580CCA in March 2002 and replaced it in Sept 2009.
