BLOS is able to reduce all the flashback
risks owing to a faulty mixture (it is
plain that it would be never able to remedy
a flashback caused by a defective sparking
plug or by a leakage of current coming from
the high voltage cables, or even by a use
leading to the complete emptying of the
LPG tank). The protection device of the
flow meter ΓΈ 70F-70M code
90AV99010033 can be installed directly on
the BLOS. On this purpose, file the metal
flat band of the BLOS body ring nut contemplated
for the air pipe coupling.
