Thread: Centre console lights
    May 2011
    Wallan
    Hi guys, I have what I think you'd consider an electrical fault with my centre console lights to the climate control and auto gear selector illumination lights.
    Bascially they just don't light up when you turn the headlights on. Thought it may have been just a fuse but they're all solid with no broken fuses. What does work are the illumination lights for the power-windows on the centre console. Is this just a loose wire or something a little more evil
    On a side note, the front internal light works when the door is opened but not when you try to turn it on manually by switching the lamp to on. Is this part of the centre console lighting problem as well? Your thoughts please
    P.S. due to my very poor internet coverage near Kilmore Vic, everytime I use the 'Search' function, I always seem to get 'Retry in 59sec'....hehe just another Gremlin in Land Rover land perhaps.. lol
    You'd better tell us what model LR you have.
    May 2011
    Wallan
    Not a bad idea Ron ...... doh !!!!!
    Got a little caught up in all the great info on the site and I forgot not everyone is a mind reader or looking out my window to know what've got. It's a 1998 Disco which makes it a D1 if I'm not mistaken (only had it for 7 days), V8 petrol/gas, 170k's. Two lpg tanks 70lt I think giving 390k's highway and 30lt petrol giving off lots of vapours in a confined space....mmmmmm
    Yep, Disco 1. I'll move this thread to the Discovery 1 section. Electronic Diagnostics refers to using computer tools to diagnose problems.
    You are going to need RAVE which includes the workshop manual and the ETM (Electronic Troubleshooting Manual) $16.50. See here: http://www.davesitshop.com/davesitsh...od&productId=1
    May 2011
    Wallan
    You are going to need RAVE which includes the workshop manual and the ETM (Electronic Troubleshooting Manual) $16.50. See here: Dave's Interesting Things - Rave I
    Thanks for that Ron, and my next question was going to be about the Rave CD and where to get it
    May 2008
    Lismore, NSW
    The lights for the auto selector should come on with the ignition key. Not related to the headlight switch.
    Not sure about the electric window switches though. They may be connected to the headlight circuit.
    The interior light operates off 2 circuits. One is the "manual" on which over-rides other systems. The other is tied into the door circuit so that when the door is opened they come on. Also they should automatically dim on the door circuit after the door is closed.
    Warren
    Currently Landroverless - Still interested
    Formerly: 2003 D2a Update TD5 Auto. Platinum edition. ARB Bar, 36" LED light bar, cargo barrier, dual batteries.
    May 2011
    Wallan
    Thanks Warren9981. I've ordered the Rave CD and hopefully should be able to start tracing the source of the problem. I see Andy thinks he's found one solution, although the autotrans lights are a worry if they're off the ignition
    But then I did buy this awesome vehicle to have fun with and I'm guessing this is just the begging
