The link below is to the Traxide people, (drivesafe on the forum), who make a pretty good dual battery interface for the 3 and 4.
Drivesafe at least understands which direction power is moving from the main starting battery and where it is coming from or going to, and more importantly, why and how. That brings up another question - is that what you were thinking of monitoring?
I think perhaps you were wondering what current the alternator is putting out at any given time or were you wondering what current the vehicle systems were drawing or - well it keeps on going, particularly with multiple batteries.
As such, the solution to what you may be asking is not easy to answer any longer. When a vehicle electrical system consisted of a generator, a battery, and a load, (the vehicle), it was not too hard to insert something somewhere to at least tell you what the battery was doing, charging or discharging, and that would mean something. Now it is not so easy.
My own view is that if you want to monitor alternator output, taking a measure of field voltage used to give a pretty good indication of load, (higher field volts, the harder the alternator was working). With these new alternators, I do not even know it they have what used to be called field voltage. I have attached the battery / alternator wiring diagram for an LR3 and the only wire identifier word I understand is B+ and maybe Batt Sense coming off a 5 amp fuse that I presume provides 12VDC power to what I used to call the Field, but somehow I think it is called something else now.
I even see a couple of locations where I "suppose" one could insert an old fashioned shunt and monitor amps in or out of the battery or alternatively, amps out of the alternator, but somehow the term "old fashioned" bothers me. I figure some Can Bus monitoring system would probably pick up on the shunt and throw a fit - well drop the 3 to the stops as that seems to be the first reaction to any concern.
Anyway, it may be simple and I may be making a too big deal of it, but the word "obvious" and my word "suppose" does bother me. The question is an interesting one however.
D3
 D4  2.7litre
D4  2.7litre
