Starting on LPG when Cold
					How do you start LPG only systems on really cold mornings.
My 101 is both LPG and petrol and anything below about 5 degrees it will not start on LPG - and I have a direct gas injection starter that squirts LPG direct into the inlet manifold bypassing the carbies etc - below about 5 degrees no gas comes through.
As I have to start it up at about 7 in the morning and expected temp is going to be about -5, I have been out running it on petrol to ensure the carbies will be full of petrol in the morning.  If I stop on gas and then the next morning try to start on petrol with the carbies empty it is also hard to start on petrol.
So - how do you start LPG only systems on really cold mornings???
