Ranga,
Have you a photo of the underside of the new tray. Is it ally or steel tray?
3mm steel angle will fail dismally in a loaded 130.
Depending on what the tray already has underneath it. Structural c-sections will be your friend.
If Aluminium I would use 127x63 by 6.5 thick C-section.
One piece runs left to right across the front of the front chassis mounts. Then two lengths run the full length of the tray sitting ontop. These are at a good width to fit your tyre. Being C-section its easy to through bolt and also attach the tray plates.
For the rear support to the rear chassis cross member you simply use more of the 127 c running along the top of the cross member, with a cutout for the tyre centrally.
This will give 250 clearance between tray bottom and rear cross member for tyre system.
S
