Results 1 to 6 of 6
Thread: P38 Body Lift?
    Question P38 Body Lift?
    Hi,
    Have just seen a P38 body lift avail on e-bay UK (looks like about 20 X bolts, washers and bushes) for around 50 pound and am wondering if anyone has had any experience or knowledge or opinion of this sort of thing.
    I was thinking bumper mounts, brake lines, etc. would get mucked up in the fitting process...
    Dave.
    Oct 2010
    Carindale, Brisbane, Qld
    I dont know squat, but I am def interested. Especially if it is removable for sale in the future.
    Now: 2005 L322 Vogue 4.4 M62TU (Black)
    Before: 2000 P38A HSE 4.6 - stately capability | 2008 Kluger KX-S | 2004 Forester | 2000 Yamaha XJR1300 | 1993 VR Calais | 1974 HQ Statesman - 308 V8 | HT | HK
    Quote Originally Posted by DT-P38 View Post
    Hi,
    Dave.
    plus sunroof and aircon drains, autotrans linkages, accelerator linkage, BECM wiring harness..the list is endless...but a 50mm lift would make some near-to-impossible access jobs a lot easier!!
    Jan 2010
    Victoria
    Quote Originally Posted by Hoges View Post
    I cant see why the aircon drain tubes, sunroof drain tubes etc etc would be an issue when none of these items are attached to the chassis. I had a 2000 mod P38a and now have a highly modified 94 mod classic (which has SRS, sunroof, auto, etc etc) with a 2.5" LRA body lift that I fitted and the only problem I could see you having is getting it engineered (if you wanted to) as your not supposed to lift the body on vehicles with SRS air bags (but if your like me it wont stop you). The only other thing you would have to sort out is the steering shaft from the fire wall to the steering box as it will need to be spaced out/extended. Go for it I say.
    Jul 2010
    Sydney/Balmain
    Sounds like a night mare.
    I cant see an awful lot to be gained by this mod.
    Buy some Arnott gen 4 air bags and recalibrate your EAS ride heights this will save you a lot of grief.
    If you do it make sure you put some pics up of all the mods you had to do and the end result of course
    If you order a kit, get 2 one for me !!!
    Jeff
