21st June 2011, 08:42 PM
Blame - key start
Hey guys I recently saw a movie called blame and in it an actor started a series land rover which looked stock by just turning the key like a normal ignition. In my series 2 I have to push a button after I turn the ignition on. Are there any models which don't require a button to start?
21st June 2011, 09:13 PM
They discontinued the button start in the 2as, before 1965 at least is all I'm sure of. Certainly, no negative earthed 2as or Series 3s were button start. It seems a bit of a loss really, when I see all these new cars fitted with "modern" push button starts!
22nd June 2011, 06:30 AM
It isn't hard to fit one if you know a tiny bit about auto electrics. I had a mid 90's barina where the ignition key was so worn it stopped working in the doors then in the ignition, so I removed it completely, fitted on on/off ignition switch and a safety switch for the starter so all you had to do was flick on 2 switches and push a button to start it. Looked great and worked a treat at only a few dollars and a couple of hours to fit. Then I added a single central lock solenoid to the drivers side front door with a concealed switch under the front guard, just a momentary toggle switch so when the lock was down, flick the switch and the door would unlock. To lock you just did it manually. I carried the key as a backup just in case the solenoid failed and I needed to get in through the rear hatch. It was great to jump in and not have to have keys for the car. Probably not roadworthy though - I think the subsequent owner would have had to fit a new ignition switch/steering lock which probably cost more than the car was worth.
22nd June 2011, 07:01 PM
#4
G'day Matpoli
The key start ignition and change to Negative Earth Electrics first appeared in 1967 (chassis suffix"D")also they changed to single cable driven wipers, and flick type switches on the dash, the handbrake lever also got a 90* bend so that drivers did not need to undo their seatbelt,(which was just coming into law in some European countries) all Landrovers after that were key start neg earth.
