Results 1 to 10 of 17
Thread: Most basic dual battery isolator?
    Yanchep, WA
    Hi all.
    Have had a quick poke around on the forum and other sites looking at dual battery isolators for my D2.
    I've got a spare car battery (from a ford focus - calcium I think) hanging around and wanted to rig up a really basic dual battery system. I've seen the solenoid solutions from ABR sidewinder on eBay really cheap. That's attractive! I just want something to run camp showers and some other incidental stuff off. No fridges etc. And cheap! Can upgrade battery later if needed.
    Will it do what I want? Charge the smaller car batt when running D2 and isolate it when the D2 is off.
    What is the bonus with going for the intelligent/more costly systems? Redarc, traxide, Sidewinder, Rottonics etc.
    Wil
    The simplest solenoid system will work, but suffers from two problems. Firstly, depending how it is wired, a dead flat auxilliary battery paralleled with the main battery when you switch on the ignition will not be the best for the main battery, although it will probably not stop you starting. The second problem is that simply paralleling them means that the charging will not be optimum for either battery, shortening the life of both batteries.
    A possible but unlikely result is that a catastrophic failure of one battery could kill the other.
    Yanchep, WA
    Hmm. Thanks for that! Less attractive now!
    Traxide.... Thats it... All you'll ever need and want
    WA
    The simplest and cheapest isolator is a marine battery switch.
    https://www.whitworths.com.au/main_i...AbsolutePage=5
    However you need to remember to switch it
    There's as much effort (and not much difference in cost) in fitting simple switch compared with fitting a Traxide SC80.
    99.87 MB
    If you want really basic, just hook them up in parrallel. Mine have been like this since the Redarc got dusted about 5 years ago and so far no issues. Mind you, i don't sit and camp for days, I'd typically move on every day which charges the system.
    Slunnie
    Mar 2009
    Port Stephens N.S.W
    As said .... Traxide SC80
    Kev..
    2014 Isuzu MUX LST with fruit
    2008 Isuzu D-Max
    2015 Kimberley Kamper "Classic"
    Gone ... 2004 D2a Td5 Auto "Classic Country" Vienna Green
    WA
    I agree on the fitting, but to be fair, the traxide is more than double the cost of a switch. Plus, you still need to buy a switch as well as the traxide if you want to bridge both batteries for winching etc...
    VIC
    If you do winching, the Traxide 160/240 amp controller is better. I just press the (included) cab mounted switch, bridged, best of both worlds.
    Thinking about putting in a CTEK 250S Dual DC-DC though...
    ...or not
