Hi Perry,
Firstly I will say I have never owned this particular HF radio though have in the past owned other Codan units. If this is anything like it's successors then its probably built like the proverbial brick ****house and should have many years of life in it yet. That said, it should have been well sited to protect it and well maintained in order for it to continue to give good service. Correctly maintained they will provide you with many years of faithful service. I've never had issues with any Codan I've had or operated, though as previously mentioned I've never owned this particular unit.
Not sure where you intend to purchase this from but would suggest you get a properly "refurbished" unit from a reputable seller. Yes, they are on eBay as well and you'll find them without looking too hard.
Now, depending on what experience you have with radios of any sort I would suggest something a little more modern might be a better choice. If you are used to operating radio equipment (were a Ham or ADF radio operator in a former life) then you should have no trouble coming to terms with this particular 99 channel unit.
No HF radio I have encountered is difficult to come to terms with but the older units do require a bit of radio knowledge or the learning curve for operation is very much steeper. They are much more complex than a UHF CB, and in untrained hands much more damaging to the RF spectrum and their operators. So, if you have never operated anything more complex than a CB I would suggest trying to stretch your budget to something a little more modern like a 9323 or if you can really stretch it an NGT. Both of these units can be obtained pre-owned. The NGT in particular is almost as easy to use as a mobile phone. There are Barrett units as well you might also consider if you don't already have a brand preference.
I suggest you have a look on this great Interweb thingy and see if you can get hold of the operation manual for the 8523/8525 and give it a read. If it makes sense to you. If you feel you could operate it without confusion then I'm sure you'll be very happy with your choice of radio.
Next, please don't consider getting a wire tap antenna to "keep the costs down". Doing so will cut costs but I can offer you assurances that you will most likely regret the decision. Go with an Autotune antenna unit. They are indeed more expensive but the convenience involved will far outweigh that initial cost very quickly in actual use.
Getting out of the vehicle to constantly change the little wire (if you don't lose it) every time you change a channel is a right PITA. Likewise they will restrict your operation to a limited number of frequencies. You will see Emergency Services vehicles with wire-tap, tuned length antennas. They can get away with it because those that use these form of antenna usually don't change frequency very often, if at all. Anyone travelling our vast country far enough and expecting to operate their radio is going to find only 12-15 frequencies very limiting. 12-15 might sound adequate but if you look at a list of frequencies for VKS737/HF-Oz/RadTel/HF-Tel/RFDS you will quickly see that number very limiting. If the frequency is not catered for on your antenna then you cannot transmit on this frequency. To do so would risk the integrity of your radio. That is you could, quite literally, blow it up. Autotune antennas don't have this issue. They can tune appropriately to whichever frequency is necessary. The naysayers will say they can't tune as accurately as a tuned length antenna which is true (and why the ES often choose wire tapped). For your intended use it makes no practical difference.
Hope these thoughts are of use to you.
Iain
Iain
VK3BIT
03MY Range Rover HSE Td6
Nudge Bar, Sat-Nav, Cargo Barrier, IC-450, IC-706 and Codan 9350, DT-90 DBS, Chipped!
LROCV DTU member
