Results 1 to 10 of 18
Thread: D3 TDV6 Service
    Tewantin Qld
    D3 TDV6 Service
    I mean to give my D3 TDV6 a birthday and change all the oils.
    I know that some of this may have been covered before, but it would be favourite if I could collect all the following data 'in a oner' to make it easy for me (and potentially others).
    So, what oil is used (and LR recommended) in the following
    Engine
    Front Diff
    Gearbox (auto)
    Transfer box
    Rear Diff (not eDiff)
    Also, when I change the oil in the gearbox is it normal to renew the filter? Probably is, but just checking as mine has the 'upgraded' metal pan and I'm not quite sure on the filter arrangement. (If the filter is changed out, where can a replacement be purchased?)
    Thanks in advance
    Up a hill in the deer park
    You going to Pacific or BOR for this lot ?
    Tewantin Qld
    Doing it myself.
    Just need the oil info' though...........
    Can anyone answer the oil type queries?
    Quote Originally Posted by dangermousehouse View Post
    Engine
    Front Diff
    Gearbox (auto)
    Transfer box
    Thanks in advance
    Engine. 5W/30-WSS-M2C913-B (only) (Fully synthetic, Castrol Professional range)
    Front Diff. Castrol SAF-XO
    Gearbox. Shell ATF M-1375.4
    Transfer Box. Shell TF0753
    Rear Diff. Castrol SAF-XO / Rear eDiff. Castrol BOT 720
    Tewantin Qld
    Hi Sniegy
    Many thanks for this, much appreciated.
    Racked up nearly 1/4 of a million kays now and still goes like new!!
    Regarding the 'improved' auto sump and filter, is the filter available from LR?
    PS - Attached is a pic of the D3 after driving the dirt road from Winton to Jundah. Twas a little wetter than anticipated!
    Other pic is the result of me 'pushing on' on a bit too quickly when the road dried out
    Hi Dangermouse,
    Not sure what other dealers stock, some may not even know about the upgrade metal pan kit, which is "aftermarket" so to speak.
    We actually buy our kits from A & B automatic transmissions in Dandenong, this also includes the oil for the transmission.
    Home
    These guys do all the LR refurbishment on the transmissions.
    Bill the owner is a landy nut also.
    Grant is the best person to speak too, knows his stuff.
    Jan 2010
    Newman WA
    Sniegy , that auto oil Shell M-1375.4 , is actually ZFLifeguard6 isnt it ?
    Doing it myself.
    How do you intend to measure when the gearbox oil is at 35 degrees c when you do the oil change? Also I guess heat the oil going in to 35 degrees so that the correct amount goes in?
    I am interested in how this is done away from the dealers.
    ....I guess heat the oil going in to 35 degrees so that the correct amount goes in?
    What's the SG at 35c vs 25c ?
    Quote Originally Posted by Neil P View Post
    I have no idea - the service specs as I understand them require the oil to be at 35 degrees. Was discussed in another thread that I cannot put my hand on at the moment. I also understand that dealers have the appropriate test equipment that reads the temp straight from the sensors - they drive it until the temp is reached and either top the oil up or change as required.
    I have no first hand experience and curious if it a major issue or no as I would like to do a simple drain and refill at my next service and do a mega flush at 96,000km.
    If someone knows the "reality" if the above is incorrect then please come in and comment.
    PS - Draining the oil is no issue but checking the level is when new fluid is added would seem to be - from the workshop manual.
    CAUTION: The gearbox fluid level must only be checked when the temperature of the fluid is between 30 degrees and50 degrees. The fluid level obtained will be incorrect if thereading is outside this temperature range.
    So I guess if you heat the oil to 50 degrees before you fill , the temp of the oil in the box should still be within the temp range by the time you get up to the filler hole.
