On my Nano 1 I use the "Record Fueling" section. Start recording and go for a drive, then load the resultant file from the Nanocom into the laptop, and open it with the Graphic Viewer .... shows all recorded parameters as a time vs value graph, that can be steeped through at 1sec intervals (road speed, eng' revs, fuel temp. air temp. inlet press', boost press', etc, etc ... )
I don't know if the Nano Evo can do this ? .... hang on .... the Nano Evo unlock pdf I have shows an Input Fuelling block .... so I assume it will do he same thing (and record the results to the SD card ?) Pop the SD into the PC ...
Does the Graphic Viewer work with Nano Evo files ??
Kev..
2014 Isuzu MUX LST with fruit
2008 Isuzu D-Max
2015 Kimberley Kamper "Classic"
Gone ... 2004 D2a Td5 Auto "Classic Country" Vienna Green
