Most of these OBD scanners can automatically self determine what is called Mode, that is the particular type of ECU electronic language that the OBD unit is told to understand.
For my ScanGauge II, my 2005 LR3 with the 4.4L petrol V8 uses the Ford mode called CANSF. VW probably uses a different language and I suspect your scanner is locked into the VW mode.
I discovered all this by playing around with the manual mode selection on my ScanGauge and not only did I light up all the trouble lights on the dash, I set the 3 down onto the stops - it was not pretty.
Fortunately, disconnecting the ScanGauge and restarting the 3 resolved all. Below is from my ScanGauge manual. I note that the ScanGauge is not sold as an OBD reader but it does some of that. I suspect that the unit you have does have a manual as well as automatic reset of mode.
FORD Products: PWM or CANSF
GM Products: VPW , ISO or CANSF
Chrysler Products: ISO, VPW or CANSF
Volvo Products: ISO, CANSF or CANLF
Others: ISO, KWPS, KWPF, CANSF, CANLF, CANSS or CANLS
