Drover,do puma's wear the flange splines like the Tdi's did?. Pat
Just got my shipment from Ashcroft Transmissions in Luton UK.
These guy's are very easy to deal with and nothing is to much bother.
All of the bits are of very high quality and the machining is outstanding.
In the kit.....
· Front and Rear heavy duty half-shafts.
· 2 x ABS CV Joints.
· 4 x Drive Flanges.
Beatrice from Ashcroft’s, arranged for the purchase to be completed in two separate consignments, keeping each under the $1000AUD’s and avoiding the import tax.
Just need to fit them now
 OldBushie
						OldBushie
Looks good Drover,
Any chance of placing one of the old shafts next to a new one for comparison photo?
Are they doing a front locker as yet?
Regards,
PeterW
Pat,
They come with an advice sheet warning to keep drive flanges/axels lubricated or excessive ware can occur, so I guess....yes
TwoUp,
Comparison photo’s wont be a problem, just need to find the time to get the old ones out.
Ashcroft’s have just released front and rear locker for the PUMA, there was a thread on here somewhere (not defender section) from a member who just got one.
nice!!
Nice, When did you order? Ashcrosft's told us they were out of flanges for 4 weeks about 10 days ago! We have ours on order from the states now. Waiting.........
 Wizard
						Wizard
						 Wizard
						Wizard
						Hey Wagoo,
Not 100% sure, I am learning as I go.
The Ashcroft site refers to the "Original thin type flange" so I assume that these new ones are longer.
They also mention to keep flange and axel lubricated to avoid "fretting corrosion".
On early oil filled swivels oil migrated along the CV stub shaft and lubricated the drive member spline, on later grease filled hubs this migration does not occur so regular attention is required
I am hoping to convert to oil lubricated during the fitting of the new bits".
