There have been other stories of this happening but nothing conclusive.
 Fossicker
						Fossicker
						Hi all .an old guy told me last week at a caravan park that his hitch receiver had fallen off resulting in his van crashing onto the road causing all sorts of damage and that i should be made aware and maybe get a hayman reece bolted on to the disco instead of the hang down type supplied can anyone confirm that this has happened or is he full of **** cheers all rog
I Know of 2 cases and got to physically eyeball one...
the one that I got eyes on the hitch was still there the ball had failed at the thread. Had the hitch failed there would have been no damage as the chains were hooked up to the same part as the ball.
An old guy told me once that when you hook up the safety chains, cross them left to right, right to left. This way if the trailer / van etc was to come off, it would rest on the chains.
That was when I was 18. Since then I have had two trailers come off and the crossed chains have saved me both times.
Cheers, Craig
 Master
						Subscriber
						Master
						SubscriberCrossing the chains is at least an official reccomendation here in Tassie, for trailers above 850Kg.
I am pretty shure though that there is an actual requirement.
That aside, there are a lot of trailers/vans being towed that warrant the pracice, getting about uncrossed.
Right or wrong I was told it is the law here in NSW's that you must cross the chains if you have two fitted.
cheers,
Terry
Terry
D1 V8 (Gone)D2a HSE V8 (Gone)D3 HSE TDV6 (Unfortunately Gone)D4 V8
Another tip is, have the chain at a length that the slide in tongue doesn't slide all the way out, this way if a pin brakes, it won't slide out and your trailer/van/camper won't drop onto the ground.
Baz.
Cheers Baz.
2011 Discovery 4 SE 2.7L
2007 BMW R1200GS
1979 BMW R80/7
1994 Yamaha XT225 Serow
 YarnMaster
						Supporter
						YarnMaster
						Supporter ChatterBox
						ChatterBox
						There have been some cases if the hitch failing to stay in. Most likely the pins had not fully connected. Mitchell Bros have supplied some hitches where this has happened but they were also told by LR to remove the mention of it on their web site.
 Fossicker
						Fossicker
						Not a myth, i had my hitch drop out while towing my 5m boat on the freeway. It was properly locked in, however the tongue mechanism failed. The only way to stop at 100km/hr was to gently apply the brakes and stop the boat by letting it ram into the back windscreen. Luckily there was not other damage.
LR investigated the tow hitch and replaced the whole assembly.
I am always nervous whenever i tow and go over a decent bump...
