Results 1 to 10 of 16
Thread: ONE DRY PUMA...
    Central Coast NSW
    ONE DRY PUMA...
    Well after 15 weeks, 6 attempts they have finally got it.....
    Had lots of rain on the central coast last night, first rain since getting the PUMA back from the 6th attempt to stop the water ingress into the front foot wells.(appropriately named)
    I left it out on the driveway last night.... just checked it and "da dar".... dry-no water leaks on either of the foot wells.
    It has had every seal replaced from the turret down to the chassis, some twice. The last time they replaced the windscreen panel seal.
    Very happy now, just goes to show – perseverance does pay off, warranty works and 3 years is only just enough time.....
    Toowoomba, Queensland
    I'm assuming the title of the thread is the worldwide total?
    AFAIK the Defender is the only vehicle I have owned where the factory publish a manual on how to stop the leaks...
    Steve
    2003 Discovery 2a
    In better care:
    1992 Defender
    1963 Series IIa Ambulance
    1977 Series III Ex-Army
    1988 County V8
    1981 V8 Series 3 "Stage 1"
    REMLR No. 215
    solmanic's Avatar
    solmanic is offline One Merc post away from being banned...
    Maleny, Queensland
    Park it on an angle to one side, then the other... then see if it's still dry.
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    Drive through heavy rain and see if it is still dry!
    If there is no water in it,please remove the Land Rover badge and send it back to the factory,because someone obviously stuck it on the wrong vehicle
    Wayne
    Wayne
    ​VK2VRC
    LowRange 116.76:1
    Nov 2008
    Gone
    At last, you will need an under body water tank now when you go away as you have lost your onboard tanks
    Allan.
    Its probably all pooling inside the bulkhead ready to rust out
    You should weigh your Defender - I bet its 20kg (of Sikaflex) heavier
    May 2009
    Mount Lawley
    Quote Originally Posted by Drover View Post
    Well done Mate, Congratulations don't listen to all the negative people, they either want a dry defender, want a puma or want a SVX and you have all three
    Quote Originally Posted by LR09WA View Post
    Or we want all three At least mine only leaks on the passengers
    Steve
    2003 Discovery 2a
    In better care:
    1992 Defender
    1988 County V8
    REMLR No. 215
    Feb 2010
    sydney
    So it can be done! I live in hope.
