Results 1 to 10 of 24
Thread: defender replacement: the benchmark (IMHO)
    Toowoomba, Queensland
    With all the Defender replacement threads, I thought I might post what I believe is the vehicle closest to what the Defender should be.
    Like the Defender it is a lineal descendent of the WW2 Jeep. Like the Defender replacement it was a ground-up redesign. Like generations of Land Rovers it is a military vehicle.
    The Jeep J8
    Military Jeep J8 road test
    Steve
    2003 Discovery 2a
    In better care:
    1992 Defender
    1963 Series IIa Ambulance
    1977 Series III Ex-Army
    1988 County V8
    1981 V8 Series 3 "Stage 1"
    REMLR No. 215
    solmanic's Avatar
    solmanic is offline One Merc post away from being banned...
    Maleny, Queensland
    Rest assured if they cock up the new Deefer I'll be looking for a way to secure one of these instead.
    WA
    I hope VM diesels have improved???
    Looks good, but I would take a g-wagen Professional over that.
    G-wagen has lockers, coil rear and a 3L engine...
    However the Jeep does have rear discs.
    the perentie.
    Mar 2010
    South Africa
    The issue with the GW Pro is the price: over here they go for USD$100,000.
    For that price I can buy two Puma Defenders.
    Jeep J8 looks good, I just hope the control arms are stronger than stock.
    SW of Geelong
    ............However the Jeep does have rear discs.
    ......and rear leaf springs
    '88 County Isuzu 4Bd1 Turbo Intercooled, '96 Defender 130 CC VNT
    '85 Isuzu 120 Trayback, '72 SIIA SWB Diesel Soft Top
    '56 SI Ute Cab
    Mar 2010
    South Africa
    Rear leaf springs are better for load carrying than coils.
    JDNSW's Avatar
    Quote Originally Posted by jakeslouw View Post
    It is not clear to me that this is the case. The only reason would be that the coil carries the load at one point on the chassis where the leaf spring carries it at two, but surely any advantage for one or the other depends on the chassis design. On the other hand, the coil has no load concentration on a moving joint as the leaf spring does at the eyes.
    The other primary difference, that the coil separates the location, torque reaction, and damping functions from the support function seems to me to be independent of load.
    You can argue that unloaded/loaded springing can easily be arranged with leaf springs by having a separate overload pack, but you can do the same sort of thing with coils as well, for example with concentric springs or tapered springs.
    Torres Straits
    Sounds like the ideal tourer to me:
    "We find that the suspension is flexible when crawling, and the high spring rates work great when running fast, but it feels really bad in medium driving speeds on the washboard roads. The semi-elliptic leaf spring setup is simply too hard when not fully loaded."
    Just how do you fit a tonne of gear to settle the rear end when all you have a is a poxy little dog box behind the rear seats??? Maybe youll need to ute-efy one.
    I wonder if the ne european VM still has four leaky head gaskets or if they have economised and now only have one leaky gasket???
    The solution to LR destroying the new defender is to just keep an old one.
    S
    VladTepes's Avatar
    Bracken Ridge, Qld
    The Merc Professional is over $150K here, projected price, what a scam.
    The Jeep does not have the same interior / cargo room as the Defender.
    Hmm
    Coil Sprung Defender - load rating 1 tonne.
    Leaf Sprug Land cruiser - load rating 750 kg.
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
