Results 1 to 4 of 4
Thread: Working with Ozi and Google Maps (or how to get lost scientifically)
    austastar's Avatar
    Jul 2009
    Hobart
    Hi,
    With a Tasmanian MySwag get together this coming weekend, and not being able to get away till Friday, it will probably be a highway run either up the East Coast, or up through the Midlands Highway and across through Conara.
    These roads pass either side of some interesting country, some quite rugged, and the thought occurred to me “Why don’t we explore the bits we usually pass around.
    Now if we had wings, we could go
    but failing that, what is in there, and how can we get there?
    The Exercise:
    Travel from St Helens to Hobart by the most direct route but avoiding main roads where possible.
    The method:
    I tried putting a straight line between the two points in both Google Maps (and Garmin Base Camp) and adjusting the route chosen by the program inwards towards the drawn line, but kept getting a huge mess on the map as the program tried desperately to keep me on main roads, like a good tourist should.
    It would have been possible in Ozi to quickly trace a route out on a 1:250,000 map, but that would have been useless on Forestry tracks, and getting down to 1:25,000 was impossibly detailed and I kept getting lost.
    I needed to break it down into smaller steps.
    Starting at St Helens with a ‘tourist’ map, there was a road shown down through the hills to the Esk Highway which was a good start.
    However I have been up in that area and it is a maze of roads, the tourist map doesn’t indicate any of the side roads, some of which are indistinguishable from the main through road. Yep, been there done that and got lost.
    With the tourist map on Ozi, I traced a rough track to act as a guide to finding roads on a more detailed map at 1:250,000
    Note the bridge at the bottom of the map at Upper Scamander, because I will use that to make some comparisons.
    The country looks reasonably wild and hilly
    On Google Maps, there is nothing to be seen at this scale.
    There is however a wealth of information if we zoom in
    How to use the versatility of Ozi and the details of Google maps to get a good idea of a route through this maze?
    You will need to register with Google so that you can use Google maps to place and store information on maps that you will own.
    Google Maps can import .kml files, and Ozi can import/export them as well – so we can use these together.
    After exporting the rough track from Ozi as a kml file we can import it to Google maps, and zoom in near our starting point so that even minor road details are visible.
    Google Maps has a nice feature that draws a line along roads in the maps data base, so zoomed in on St Helens above, it is dead easy to let the line follow your pointer down the road. Move the map with the arrow keys to avoid spoiling your track.
    Just keep on leading the line down the road.
    Ok, next bit is a problem. The road is not in the Google data base. We are going to have to change tactics.
    Click the last point on the road to finish that track, and we will continue on using a manual drawing tool. This tool knows nothing about roads, so you will have to guide it.
    The road is not shown on the map, so switch to satellite image view, zoom right in to get the detail you want, but not too much so that you lose your guide line.
    Switch to the straight line drawing tool and follow the road with as much detail as you feel like you want.
    We have to get from the top left of this image to the bottom right to where the marked road continues.
    We are now back at the road.
    Click the end of the road you have just traced.
    Swap back to the line tool that follows the road and continue down to the highway near St Marys.
    We now have completed the trace, but have a map with a lot of construction lines that we can delete.
    Line 1 is the original direction line.
    The 3 pointers are where I was checking some details
    The blue line is the rough trace from the tourist map
    The 3 lower lines are the traces we want to keep, so all the other items get deleted.
    Now here is a little ‘Gotcha!’
    The little KML in blue is the export button, the other little button exports a link that only Google Earth can use, it is of no use to Ozi at all.
    So how did it all work out?
    Import the kml file into Ozi
    Remember the place we lost the road? Here is a bit of the 1:25,000 map with out and with the kml file imported over it.
    It has joined the missing bits of road nicely, and follows the roads pretty well exactly at that scale.
    On my 1:100,000 the road was not shown at all
    Now the trace shows it nicely, and I am confident it is accurate.
    OK, I’m confident I can find my way through that little maze to the next highway, now it is just a matter of doing the same for the rest of the way back to Hobart.
    I will have an accurate trace in Ozi, that I can view in 1:250k, 1:100k or 1:25k.
    What could be better?
    But wait! There is more.
    Ozi can export the kml file as a gpx file (gps exchange file)
    and this should be able to be imported via Base Camp to the Garmin which takes up much less room in the vehicle.
    I have yet to try this, and it will be the subject of another posting.
    Nov 2008
    seaham (gods country) nsw
    will be interested to see of it goes on your garmin.
    try and see if you can get digital images of the 1:100000 topo maps
    https://www.tasmap.tas.gov.au/do/category/100000TOPO
    we can get them digitally in NSW for about 3 bucks, but cannot in the brief search i did see them for TAS. These maps show all the public roads and the older ones show the cadastre also, which can be useful to see if you are going through peoples properties, as they might lock their gates, even though it is a public road.
    i can download these maps to my gps so i can get my position on the 1:100000 maps. would be good if there was something like this for tas as it is such a nice place to explore.
    Also some useless trivia they are starting to change the name of GPS to GNSS (global navigation satelite system) this is because GPS is the yank system, the russians also have a system up called GLONASS, the european union is currently putting up a system called Galileo, and the chineese are working one one as well. so GNSS encorporates all systems.
    still i doubt people will start calling it GNSS, its just harder to say.
    also while i am on navigation systems, a system is being developed which is a land based gps system basically. just put transmitters up on high points, or even adapt phone towers as transmitters so you take out the satelite moving around the earth variable, basically making a system to use around the country accurate to cms with just a phone gps. then you take out all the yank spoofing etc. cant remember the name of it off the top of my head.
    sorry to take it off topic
    austastar's Avatar
    Jul 2009
    Hobart
    Hi,
    thanks for the updates (they are making it even harder to get lost eh?)
    The last map above is the 1:100,000 series, it was missing the road in this exercise completely. I have a full seamless version in ecw format that covers the whole state which is good in one way but is too big to break down into Ozf fliles for using with Ozi CE damn it. The 1:25,000 is even bigger, but I have managed to break down the 1:250,000 version for a friend.
    Unfortunately you can never know what has changed since publication, which is why I like to check on Google and as a last resort, use the satellite imagery.
    Feb 2011
    Brunswick, Victoria
    Hi austastar,
    your google routing technique is very cool. thanks for sharing.
    Paul
