Depends on their condition - any wear should be apparent; replace if wear could be measured with a micrometer (you don't need one - if there is a step you can feel, discard. If it is the latest type with roller bearings top and bottom, there should be no wear on the pins (unless it has been low on oil). If it is the older type with a railko bush at the top, the pin will wear, but, again subject to never running dry, the wear should be almost nil.
