The heavy duty rims akk Wolf rims, came out with the td5, before this you still had heavy duty rims just another type of pattern rim. 6.5 j x 16 is the old rim size, I have 5 wolf rims if you are interested .
Morning all and a happy Fathers day to the Dads out there
I am looking for Std Rims for my 2005 130 Defender, How far back in years do the same rims suit my 130 or are they all the same?
Enjoy the day
Thanks Juddy, I have an eye on a set up this way, he said they came off a 1997??? model defender, These should fit mine i take it? Is $40 per rim OK?
Bzzzt, wrong.
The holey HD (Wolf) rims came out in '97 or so, a lot of 130 Tdi's had them standard.
Natt, be careful, 110's only used a 5.5" rim which has a different offset (33mm vs 20.6mm of the 6.5" 130 HD ones) and don't have the same load rating as the 130 rim, which uses a heavy duty centre.
