Originally Posted by
Yorkshire_Jon
I personally would keep the nuvi, maybe looking at updating the maps (you can buy them from Garmin) and run it on 12V (basic 12V-mini USB off ebay).
Then, Id buy Memory Map AusTour or Memory Map Hema 4WD and run those on your laptop with a gps unit connected (I use an GlobalSat MR-350, available anywhere), or iPad or iPhone. For the apple devices you'll need to buy the memory map app.
The alternative is one of the more expensive all in one devices, like the Hema Navigator.
Depends on budget and what you see as most applicable to your needs.
The memory map software is probably the most intuative to use, others swear by OziExplorer and the plethara of maps that are "available".
R
Jon
