Results 1 to 4 of 4
Thread: spotlight security
    May 2008
    Rockhampton
    spotlight security
    Hi guys I'm in the process of modding my bullbar to take Hella rallye 4000 lights.
    I've noted you can get special lock nuts. I ws thinking these maybe a good idea. also by gusetting the mounts you can't get spanner in there, only sockets (which if i didn't use lock nuts I'd definetely do). haven't done that yet but think I will.
    the Hella lights have 2 adjutment screws which if fully undo the lights without the mounts would be loose so able to be flogged.
    inside the mounts there is the 1 centre screw for mounting the light then 2 holes on the either side of this hole still on the botom like this (|o0o|), could something be done with these?
    any ideas or other tips?
    Last edited by brend0n; 24th September 2011 at 04:18 PM. Reason: added info and retyped to make it make sense
    The lock nuts can only be fitted with a socket as the ones I've seen have a multi-pin engagement system with the pins at assorted positions. The side holes could be for stabilising arms to stop vibration.
    Bacchus Marsh Vic.
    Bit hard to understand your post mate but I think I got what your after
    I have a set of locknuts on the driving lights on the Disco.
    Got them from Oppisite Lock, same set up as the wheel nuts.
    I still think they could be undone with a chisel/screw driver and hamer.
    It's about getting the 's to move on to an easier target.
    On the wifes little run around I drilled both the mounting and adjusting bolts and fitted some cleave pins.
    The ones you tap in/out with a hammer.
    They can be loosened but not removed with out knocking out the pins.
    Can you fitt linger bolts to the ones for adjusting?
    Maybe you could put a nyloc nut on the end inside the light then.
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    May 2008
    Rockhampton
    yeah its is a bit of dribble...
    you can sort of see it in this picture. the 2 adjustments screws (the large black circles allen key screw heads)...if those are undone the light is completely separate, so the light will be gone and the mounts left.
    I was thinking a small amount of wire rope inside the mounts tagging the mounts/light together would help
    the 3 holes are in the mount not sure what the outside ones are for. but i think I sorted what I'm doing now
