Results 1 to 10 of 14
Thread: Does Hill Descent control work in reverse?
    Aug 2010
    Hi all,
    Just a question of the operation of Hill Descent control and does it work for the "Old Stall Recovery" method?
    Yes I know you won't actually stall the Auto but progess can lead to the possibly dangerous action of having reverse down a very steep incline. Sometimes wheel slip is a common issue with lost of steerage.
    So does Hill Descent actually work in this instance?
    I've had a couple of instances where bystanders have witnessed my wheels locked and just sliding with HDC being used.
    Up a hill in the deer park
    [ame="http://www.youtube.com/watch?v=4U-yFmnu0sY&feature=related"]Range Rover Sport + Land Rover Discovery 3 / LR3 extreme steep climbing - Pro7 Galileo Fake Check - YouTube[/ame]
    Only wimps reverse down
    Nanny state UK...
    HDC does work in reverse...
    ...just remember to keep your feet off the pedals!
    BTW - If you let an auto roll backwards, you can stall it.
    M
    Dec 2010
    Parkdale, Melbourne
    I must work out how to actually adjust the speed on the HDC, it's one of the things I've never actually fathomed out, other than mine is set quite high which has led to the occasional moment.
    NSW SW Slopes
    I've stalled mine trying to go forwards - several times on one occasion.
    Dec 2009
    Quote Originally Posted by Mike_S View Post
    One the D4 you use the cruise control buttons to set the speed. The display will also show what speed you have set.
    Mar 2010
    NSW South Coast
    I stalled the 2.7 a couple of times attempting big red in the simpson. I slowly ground to a halt near the top and she stalled. Cheers Chris
    Nanny state UK...
    You need to use the +/- switch on the cruise control. I'm sure you'll be able to work out which way the target speed goes when using it...
    M
    Nanny state UK...
    Quote Originally Posted by eddomak View Post
    D4 will show you what speed you are doing. Only Range Rover (10MY onwards) shows you what speed HDC is set at.
    M
    Mar 2010
    Peregian beach
    HDC does seem to work in reverse but it always seems too fast to me. Must be because you are going backwards and psychologically don't feel you have the same control.
    I nearly put a hole in my seat one time as my sphincter contracted going down a steep bit backwards.
