 Originally Posted by
TimNZ
				I had the "power cut" issue once on my 08 Defender, dealer diagnosed the problem to be a sticking egr valve causing high cylinder head temps, which resulted in the ECU putting the car into limp. There were no warning lights, or DTC's to back this up, however the car never did it again after the EGR valve was changed.
As for the temp gauge.... I'm not sure why it would wave about. If it was permanently all the way up, (ie at FSD - full scale deflection), that would indicate the ECU is in a "resetting" state.
Hope this helps,
Tim
