Garry, you have to use the numeric key pad, not the numbers above the letters.
Press and hold the Alt key then type 0163
GBP £ - Alt 0163
Cents ¢ - Alt 0162
Euro € - Alt 0128
How do I type in £ on our Aussie Keyboards (the £ is a cut and paste). I have googled it and it says to go Alt FN and type 0163 but it does not work.
GBP £ - Alt 0163
Cents ¢ - Alt 0162
Euro € - Alt 0128
Hold "alt" and enter 0163 on the numeric keypad.
EDIT -
Beat me to it.
Alt 255 was always a good one to use in a password. It would display what would look like a "space", but was actually a blank character.
That makes a lot of ¢¢¢
Thanks quids £££ Ron and d@rk51d3
My two bobs worth
Bob
Bob
Marvellous what you pick up on here.
The good old days of DOS, BASIC and HEX editing.![]()
Thanks for that but I do not have a numeric keypad on my laptop.
You can change the default function to something a little more memorable if you like. For example, shift+4 gives you $, but you change the function for £ to say Alt+4 or CRTL+4.
I used to use Degrees a lot so changed it to Alt+o plus a few others that were easier to remember and quicker to use.
You can mod it under Char Map or where you access inserting special characters.
Andrew
Using Capitals, the difference between helping your Uncle Jack off a horse or helping your uncle jack off a horse...
Copy and paste the one above?
Sam
Or, turn on the embedded numeric keypad ... most laptops have them.
Kev..
2014 Isuzu MUX LST with fruit
2008 Isuzu D-Max
2015 Kimberley Kamper "Classic"
Gone ... 2004 D2a Td5 Auto "Classic Country" Vienna Green
