Results 1 to 8 of 8
Thread: TDV6 major service costs
    Narre Warren South
    I'm actually running a Territory diesel with the TDV6 not a Land Rover but wondered what the additional costs are for a major service on this engine.
    Ford have published service costs for the Terri D and the major service is about $200 more for the diesel than the petrol.
    I also noticed that the price for a coolant change is much higher for the diesel motor.
    Can anyone shed some light on why the costs should be higher.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Up a hill in the deer park
    Why are you not asking the Dealer for a costs-break down
    and explanation ? As for coolant , by the time you see any of that
    , Juliar will be a distant memory.
    I cannot speak for the TDV6 in a Territory but coolant in a landie TDV6 has a service life of 10 years - SUBJECT - to a specific gravity test at each service within specs. Not sure if it will last 10 years but I would have thought a routine coolant change in a Territory will not be required for a long time.
    Narre Warren South
    Quote Originally Posted by Neil P View Post
    I'll be asking the dealer for the cost breakdown, just thought I'd get the 'heads-up' on here because you can't always believe what the dealer tells you.
    Any ideas what extra costs there are on the major service for the TDV6 motor ?
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Narre Warren South
    Garry,
    That sounds like a long time between coolant changes, is there a kilometre limit as well ?
    I did the old model Territory after 4 years, easy to do except I was caught out by the single use hose clamps they use. Still intrigued as to why the coolant change costs are higher for the TDV6 than the petrol. Is it a different specification or just a PITA to do the job ?
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Quote Originally Posted by gromit View Post
    Garry,
    Colin
    No km limit - note the coolant is to be tested at every service so if it meets specs there is no reason to change it.
    I have no idea about why the diesel coolant service is more expensive except that it might need more coolant.
    Sep 2011
    baldivis, WA
    Talking
    The reason ford charge more for the diesel service is the additional costs compared to the petrol. These costs being a diesel fuel filter, extra cost for lube oil ( more of it ),
    is there a sensor on the pump which needs a blow with some air, air filter will be more expensive. Coolant is dearer. Probobly a few more things which im sure the dealer would be more than happy to discuss with you. Let us know how you get on. As for the single use hose clamps im sure you will find that the little screw cover pops off with a small flat blade screwdriver allowing you to undo the clamp and reuse. Unless they have changed them again, its been a few years since i have been on the tools.
    steve
    Narre Warren South
    Quote Originally Posted by baldivistribe View Post
    steve
    Steve,
    It has to go in for some warranty work plus the first service is not too far away so I'll try and get clarification on the costs.
    I'll check out the original hose clamp from the old Terri. I remember using Vise Grips to get it undone but didn't check it out any further I just replaced it.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
