Thread: D1 300tdi problem
    weeniman Guest
    D1 300tdi problem
    G-day everyone
    i have a small problem with my disco, I went off road this weekend and now my rev counter has decided to die on me.
    Everything else is working ok but its really annoying not having it.
    Any ideas as to what may be causing this to malfunction would be greatly appreciated.
    Thank you
    Justin
    Apr 2007
    South Australia
    Not familiar with them but do they run a wire from the alternator like the petrol? Might be loose/come off?
    2007/2002/2000/1994/1993/1988/1987/1985/1984/1981/1979/1973 Range Rover 1986 Wadham Stringer
    and a Nissan Cube............
    South Australia.
    Crafers West South Australia
    Quote Originally Posted by jsp View Post
    Dead right, also check the alternator is actually working (warning light comes on with key, goes out with starting, volts rise to around 14V with a few revs). Otherwise you may suddenly run out of electrickery altogether!
    Landy_Disco Guest
    rear of alternata
    i had the same problem on my 300tdi. In the rear of the alternator there is a small wire with a plastic connector. jiggle this connector to better the electrical connection. if this doesnt fix it you may have more serious problems.
    Oct 2011
    Hastings, East Sussex, UK
    Did you get the alternator very wet and muddy?
