Results 1 to 3 of 3
Thread: Defender Vs Disco 2 Coil Perche and Shock Towers
    Aug 2009
    Brisbane, Sunshine Coast, Gladstone, QLD
    Could anyone tell me if the diameter of Defender front & rear coils and coil perches are the same as those on a Disco 2?
    Would Defender front shock towers bolt to a D2 perch?
    6" diameter on all apart from 110 and 130 rear which are 7" diameter
    so d1 front and rear = 6"
    d2 front and rear = 6"
    d90 front and rear = 6"
    110/130 front = 6"
    110/130 rear = 7"
    The towers will fit to the chassis yes. obv the std shocks wont fit then but I guess you are going way beyond std
    Aug 2009
    Quote Originally Posted by Psimpson7 View Post
    Pete,
    Thanks for that.
    I am looking at +75mm shock towers with a 12" travel pin top connection and eye bottom connection shock.
