Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: Holden v6 into Defender 110 ute
    Nov 2007
    Townsville Nth Qld
    Has anyone ever looked at converting a defender 110 , to a v6 commodore motor, vr vt. Or any information on doing so. I love my 30tdi defender ute but also the vt sedan. If i fitted the commodore motor i recon i would have the best of both worlds. Advice , abuse, opinions welcome. Letem rip
    Yinnar South, Vic
    Wouldn't bother, defender is to heavy, ls1
    South Sydney
    if its a badge thing suit yourself, but i personally would prefer a straight 6 so i'd go a ford motor (nothin to do with badge) or a big diesel, maybe a chipped td5
    Jun 2010
    Rockhampton, Queensland
    Quote Originally Posted by MR LR jnr. View Post
    I was always told that the holden v6 is not suitable for 4x4 because of the torque curve of the motor. (Not much in the bottom end) Not sure what cam options are available though.
    If you really wanted to use the 3.8, a supercharged one would be the best option as it would give a bit more torque.
    The ford six would be the best engine, but you are gonna use a fair bit of fuel. Ford Territories use a decent amount of fuel and they are no Defender!
    Put a VNT onto the TDI and play around with it.
    Jan 2010
    Newman WA
    Why not , these old fuddy duddies simply dont know whats out there , the 4.2 stroker V6 puts out better than 230KW (yes KW not HP!)and has 400Nm torque , (miles better than the crappy 4.6 RV8 )The supercharged version of the ecotec ,about the same .Its only a matter of careful cam selection to bring the torque curve down into a more useable range (only thing is, is there any suitable adapters to do the conversion with ?)
    Brisbane, Inner East.
    Buick had a 4.5 litre turbocharged version in the early 90's which was a real road rocket.
    URSUSMAJOR
    East-South-East Girt-By-Sea
    1.20 MB
    The Rover V8 started off in a Buick, did either Rover or GM/Buick change the bolt pattern for the bellhousing between the Rover and current GM V6s?
    Irymple, Victoria, Australia
    try, "Marks 4WD Adaptors" as they do a lot of engine conversions and
    they may have what you want.
    Cheers Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    billy bob Guest
    I put one in a hilux years ago. Because the motor lacks torque the fuel economy was just woeful. Up around 24l/100k from memory. Go a V8 or diesel.
