My idea was to make my own more insulated version by buying say ~5 mm rubber mat, glue high density foam or neoprene to it, and cut to shape. I'm yet to find a good supplier of said materials on Brisbane northside though (apart from Clark Rubber - ch-ching $$$$).
James.
I'm planning basically the same for those areas, although I'll use vinyl or thinner rubber to glue the insulation to. I've bought a roll of self adhesive hook and loop (Velcro) tape to hold it in place. This way it can be removed for cleaning or corrosion inspection.
