G'day All,
Can anyone let me know the approximate dimensions at A & B in the drawing below of Defender alloy wheels. I presume most of the standard alloys will be the same offset. 'Boost' alloys are the most common alloy on Defenders, so that would be a good start, but if you have a different type and can measure them I would really appreciate it.
I'm in the process of designing accessories brackets which poke through the middle of the wheel on a spare wheel carrier, so I need the dimensions to make sure things will work.
