A mate is looking for a bull bar for his 2010 Puma. Needs to be winch compatible and preferably able to take the Hayman Reece tow bar sleeve so that if can be fitted with a front tow ball if required. Any ideas or recommendations on models?
Unsure about the front towbar compatibility but I used Gordon down at Opposite Lock Rockdale. He's a Defender driver himself and the OL bullbar does the job for me. Good space between the bar and the lights/ bodywork. Good visibility of the corners when parking.
I was planning on getting a simple bolt on A bar for my puma but have had a hard time finding one due to the uk outlawing them.
I have now decided to go with a tubular winch bar. I have found a fair few; the main three are britpart, shadow (first four) and terrafirma:
I like the britpart the best as the winch shelf sits outt past the bar allowing the A bar to sit closer to the grill compared with the other models. The A bar has a more angled shape which I prefer compared to the other two which are rounded.
Cant say I have found any with front tow hitchs, may need to add one yourself.
I don't think you find a manufactured bar that has a tow hitch in it. I think they would be considered illegal. You would probably have to fabricate something for yourself.
I have a TJM commercial winch bar which seems good, classic lines and not too heavy. The only grip I have is the indicators can get punched out of their mount and broken if you happen to plough into mud, or maybe water.
