Results 1 to 6 of 6
Thread: Antenna Locks
    Oct 2011
    Fremantle WA
    Antenna Locks
    I've checked the dreaded www etc, but nowhere have I come across any locking systems to stop our lighter finger bretheren from removing CB etc antennas/aerials from bull bars or other external mounting points. I must be using the wrong search words?
    Geelong, VIC
    One of these might do the trick.
    Just needs the antenna cable to be disconnected from your radio...
    Antenna Lock
    Steve
    Feb 2010
    Wangaratta
    Try some thread locker (i.e. loctite)
    OR
    I believe Mobile One Communications sell antennas / mounts with a anti theft screw thingy.
    Good luck
    Matt
    'Tis a bit hard to lock down the average UHF CB antenna but for HF, scroll down on this page: HF Radio Antennas & Accessories
    loctite... something like 690 should do it.
    Loctite isn't such a good idea as you reduce the contact between base and antenna.
    Just take it off when not in use....
