Results 1 to 10 of 39
Thread: Stainless steel wheel nuts....Legal ?
    SW of Geelong
    I notice there's a company in the UK making stainless wheel nuts (M16x1.5) to suit Land Rovers with steel wheels fitted >>> Wheel Nuts in Marine Grade 316 Stainless <<< GBP70 for a set of 20.
    I like the idea, as they are enclosed and don't rust, but would stainless wheel nuts actually be legal to fit ?
    They come in a choice of polished or unpolished. I would go for unpolished, otherwise they would be the only shiny thing on my County
    I'm waiting on a quote for delivery to Oz.
    Cheers, Murray
    '88 County Isuzu 4Bd1 Turbo Intercooled, '96 Defender 130 CC VNT
    '85 Isuzu 120 Trayback, '72 SIIA SWB Diesel Soft Top
    '56 SI Ute Cab
    It'sNotWorthComplaining! Guest
    Hasn't stainless steel got a lower tensile rate?
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    that it has and it also binds a hell of a lot easier..
    wheels nuts are not usually done in high tensile i wouldn't think
    but the binding would be a big issue for me...
    not a game i would like to be playing.
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Yinnar South, Vic
    Quote Originally Posted by incisor View Post
    That, very much, bound stainless, is satan's mother.......with PMS
    SW of Geelong
    It's not sounding like stainless wheel nuts are a good idea then.
    Just for interest, this is the quote they sent..........
    23 of the non polished type will cost £80 and will cost £40 to ship to Australia
    '56 SI Ute Cab
    Oct 2011
    Hastings, East Sussex, UK
    How many replacement standard nuts could you buy for that money?
    Ringwood, Vic
    Quote Originally Posted by Terrain Vehicles View Post
    And get them plated to look like stainless???
    Don;t see the point really, but each to his/her own
    D4 SDV6, a blank canvas
    Kiwiland
    Stainless only binds to itself. It doesn't bind to other steel threads or the average wheel stud.
    The yeild strength of 316 is roughly double that of "mild" steel and the tensile strength 50% higher. Neither of those are cause for concern.
    http://www.matweb.com/search/DataShe...c26227c&ckck=1
    About four if you buy them in the wrong place.
    Quote Originally Posted by Dougal View Post
    MatWeb - The Online Materials Information Resource
    Also worth noting that Landrover wheel studs/nuts are far stronger than they need to be - compare the PCD and stud diameter on any comparable vehicle. (Refers to Landrover Series, Defender/90/110, 101, RRClassic, D1.)
    I cannot see a problem with them, but I would question whether they would have any advantages other than bling.
    Brisbane, Inner East.
    I am pretty sure wheel nuts are not made of any fancy steel. For many years lots of makes used brass.
    Stainless can be a bit of bugger. I would run a tap down the new nuts and a die over the studs and clean off any swarf before first use and always use nickel antiseize. Maybe kiss the inner end of the nut with an appropriate sized drill to give a taper lead-in.
    URSUSMAJOR
