Results 1 to 8 of 8
Thread: Cylinder Compression Test
    May 2008
    While I've got the plugs out today, figured I might do a check on the compression, since I've got a test set here and have never used it...
    1999 4.0 low compression engine with 178k. Head gaskets and heads were replaced 2 years ago.
    It was a dry test, and I didn't warm the engine up first (oops).
    Plugs removed, fuel pump fuse and relay removed. Battery charge ok.
    Results in PSI:
    1 = 130
    2 = 130
    3 = 125
    4 = 130
    5 = 145
    6 = 130
    7 = 130
    8 = 140
    Should I be concerned?
    Would you expect the results to improve (or worsen ) when done again "wet" and/or at running temperate?
    Paul.
    Coogee, South of Fremantle, WA
    Why are you looking for problems? stick the old plugs back, change the engine oil and carry on as before. Well that`s what I would do. If it ain`t Broke.................
    all are just within 10% so your ok...
    Id do a leak down on #3 just to find out where the compressions going.
    May 2008
    Thanks guys, will see if I can pick up a leak down tester from an auto shop tomorrow. I might even have enough air fittings in the garage to bodgy something up tonight.
    Fuel consumption has been up a bit in the past few weeks and am looking at simple things... might just be some bad fuel, the MAF and/or air filter is filthy.
    To do a wet compression test, how much oil should I squirt in the cylinder?
    Use a syringe or a bit of clear tube I guess?
    Paul.
    Dec 2009
    Tyrendarra Vic (South West Vic )
    Compression figures look O'k. For a wet test 2 or 3 squirts from an oil can is all that is needed.
    Not to much to worry about tho. As others have said "If it aint broke don't fix it "
    Gary
    less than 10ml but every pot must recieve the same amount...
    usually once Ive put it in I turn the engine over by hand 2 full turns before going the starter, this ensures that your not going to "hydraulic" the piston and blow the gauge apart.
    Jul 2010
    Sydney/Balmain
    I wouldnt bother with a wet test,
    Why?;
    How do you ensure the oil is all the way around the bore?
    Is it a real world test?;
    Not really, is it normal to have that much oil on top of a piston?
    A warm test is the best way i would say.
    Any compression test will give a different reading according to how fast you are spinning the engine.
    All compression ratios are is a measurement of volume within the cylinder at maximum (volume) compared to minimum (volume).
    You dont seem to have a great deal of variance across the 8 cylinders, up to 10% is the accepted range and beyond this you would probably start to look at valves/rings as a possible problem.
    Yinnar South, Vic
    Quote Originally Posted by RR P38 View Post
    Why?;
    I agree, wet tests are a waste, if the compression is down to be of concern, your taking the heads of anyway
    Warm it up, pull plugs, crank it with wide open throttle
