Thread: Diesel Injector and pump repairs
    Oct 2010
    Yarra Valley Victoria
    Hi All.
    Can anyone recommend someone in the eastern suburbs of Melbourne for diesel injector and injector pump reconditioning?
    Has anyone tried these repairs themselves and been successful?
    Cheers simon
    cant reccomend anyone in melbourne,
    but yep, IVe done the injectors and the pump before.
    Oct 2010
    Thanks Dave, was it a difficult job? It just seems a very expensive process to have done professionally
    Jul 2011
    Yarrawonga, Vic
    I can reccomend Deisel Tech in Lilydale
    12/ 64 Beresford Rd
    they also do a before and after dyno test.
    Quote Originally Posted by VK3UTE View Post
    3/5 for the injectors
    4/5 maybe 5/5 spanners for the injector pump
    no having it done professionally is not cheap, but the consequences of getting it wrong when DIY ing can be more expensive.
    drip no good, need a strong spray
    I have been successful at rebuilding CAV pumps for tractors, but have only swapped over the injectors, never having access to a hand pump to test them.
    Blairgowrie, Vic
    See David Rankin at Rankin Diesel in Bayswater.
    Good operators but not cheap.
    Pete
    Dizzie, 08 D3 TDV6 SE
    Quote Originally Posted by wrinklearthur View Post
    the pump is more or less the same as those, just the governor setup changes a little but its those little changes that make the difference between a normal running engine and one that decides that redline should be up somewhere near C
    Narre Warren South
    I've been told that AG Diesel on the Westall Bypass is the place to go. A car repairer I know recommended them as he takes all his diesel problems to them to be sorted.
    Colin
    Last edited by incisor; 12th December 2011 at 08:29 AM. Reason: removed name and shame
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Oct 2011
    North West Vic
    i know this is a thread big but i have smoothing important to add to anyone who is searching.
    if you do the pump yourself leave the air intake open near turbo if fitted and have a large book and helper when you start it.
    if the engine runs away get the helper to quickly cover the intake to kill the engine.
    i have seen this done with a 350hp blown detroit diesel that had intake swapped and put together wrong.
    it only ate 2 pages.
