Results 1 to 10 of 22
Thread: Reverse lights & ADR's
    Hawthorn, Victoria
    Hi,
    I've installed some LED lights at the rear of my Defender. I have wired them up to turn on with the reverse lights as well as a switch to turn them on independantly.
    I'm just interested to know if there are any ADR's or other laws that relate to reverse lights and how bright they can be?
    Any thoughts?
    Nathan
    Canberra, Australia
    I think you must have them switched so they only work with reverse etc
    I put a relay ii a set i setup for a friend so that when the engine was running they only worked when reverse was selected
    Turn off the vehicle and they could be switched on separately
    This way they made great work lights
    Michael T
    2011 L322 Range Rover 4.4 TDV8 Vogue
    Aussie '88 RR Tdi300 (+lpg), Auto (RIP ... now body removed after A pillar, chassis extension to 130 & fire tender tray.)
    East-South-East Girt-By-Sea
    1.20 MB
    You cant have reverse lamps which can be switched on manually from the drivers position while driving. So you either need to have a interlock that prevents the lights being on if the engine is running or the manual switch is not in the front of the car able to be reached by the driver.
    Hawthorn, Victoria
    Cool, I've just wired up a switch in the back... couldn't be bothered wiring up one in the front - looks like my laziness has paid off!
    Nov 2007
    Gold coast
    Following on from our chat on reverse lights, the chaps at the compliance place up here said you could fit reverse lights that work on a switch, the 90 was done this way to pass, maybe they don't know what there on about.
    South Yundreup,WA.
    Yes there are ADRs regarding this and any light you buy in Australia should have an ADR compliant status on the packaging as a minimum.
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    Mar 2009
    Soon to be Hobart
    The ADR 1 states...
    "Reversing Signal Lamps.
    Lamps that are switched on automatically whenever revers gear is selected and the ignition is on to signal the driver's intention to reverse and to aid the driver in reversing manoeuvres at night. these lamps must only operate when the vehicle is in reverse gear and must be amber or white."
    However they can be covered under ADR 45 as "search lamps".
    BUT.... to pass either you have to have them just manually switched or soley controlled by the reverse lamp circuit.... you can't have both.
    Also some state laws may restrict things on top of this.
    Jan 2009
    Samford
    So, who wants to post a wiring diagram to have reverse operation only when engine is on, and manual work/search light function when engine is off? This covers all bases doesn't it?
    James.
    Sep 2010
    Qld
    My 75 S3 has a manually switched spotlight at the back wired in with the factory reverse lights. At present not running through a proper reverse switch (soon to be rectified) and when it went through roadworthy and one of the "defects" was that the reverse lights didn't work, I simply said that they were non original and manually switched, which he was happy with, and it passed. So obviously the RWC places do not adhere that closely with ADRs nor do they check facts.
    My plan is to maybe fit an led bulb to the spottie if one is available of sufficient brightness to eliminate the need for a relay, as I think the spotlight bulb is too big to run from a stock standard reverse switch.
    Mar 2009
    Soon to be Hobart
    Quote Originally Posted by rainman View Post
    So, who wants to post a wiring diagram to have reverse operation only when engine is on, and manual work/search light function when engine is off? This covers all bases doesn't it.
    Not quiet... if it's connected to both you can't classify it as either a search light or reverse light... and therefor it doesn't pass the ADR.
    Also with regards to the roadworthy guys letting it past..... it's always possible. However even the same person might let it go one day and stop it another day based on how they feel
    Having said that, I don't think you'd ever really get pulled up on it
