Thread: ZF gearbox question - petrol & diesel D1s
    in the wild New England, NSW
    My question is: regarding the D1 ZF gearbox.....
    Is the gearbox used in the V8 any different from the one used with 300 tdi ?
    - if it is different - what are the points of difference ?
    thanks
    Goolwa SA - but top ender forever
    AFAIA it is the same a ZF4HP22
    Aug 2008
    16.28 MB
    zf
    different ratios in petrol and deisel
    Moruya Heads/Sth. Coast, NSW
    Quote Originally Posted by 87County View Post
    thanks
    Different valving/shift points/ bellhousing/Torque convertor, I'm not sure about the gearing, Regards Frank.
    Quote Originally Posted by INDABA View Post
    so.... do you know what they are ?
    (RAVE indicates differing lock-up and change speeds tdi/V8, so I can understand Tank's comments but RAVE gives no reference as to ratios)
    if it is just valving -does anyone know if a simple valve block change enables a ZF that was in a V8 to be installed in a tdi ?
    (because 2nd hand ZFs that are/were in V8s are available very cheaply)
    one of the projects Ive got on the side is a semi dead v8 auto that I was going to strip down to show how it all works...
    if youve got a TDi one down there and it can be gotten to here then Im happy to lay spanners on to find out whats different where.
    Thanks Dave, the one in question isn't mine - but it's in a tdi and is "slipping" (according to the owner) so I'm anticipating some repair/replacement action action will be required in the near future and I was wondering if a cheap alternative is a V8 D1 ZF.
    Vic
    Quote Originally Posted by Tank View Post
    All the above but the main thing is the input shaft and front pump as they are made to handle the vibration.
    Cheers Casper
    as a temporary fix you can use a slip stop additive
    http://www.wynns.net/product_files/A...4506%20PIS.pdf
    Lucas automatic transmission additive stop slip | eBay
    Lucas Automatic Transmission Fluid Conditioner - 591ml | eBay
    it'll help put off the inevitable...
    you might get lucky and find that the "slipping" is actually the TCLC on the way out which means if you do an oil sample and its got fine black floaties in it a fluid change to prevent further damage will allow you to just replace the TC without having to rebuilt the box.
    relying on those addatives is just going to make the final repair cost higher as the damage done will be greater.
    Geelong, VIC
    Definitely check if its just the TC lockup clutch slipping. Had that same problem on mine and got the converter overhauled with heavy duty clutch and some other improvements for a bit over $300 (couple of years ago) and I did the R+R.
    Was still going fine when I sold it a few months back.
    The auto trans places were talking trans overhauls for $3-4K....
    In Melbourne I can recommend Autoflite Engineering in Thomastown who did mine. Great to deal with and turned it around in a couple of days.
    Steve
