Thread: Winning noise (or humming noise) coming from the front or maybe clutch.
    Mar 2010
    Cairns
    Defender tD5 2005
    I have a winning noise (or humming noise) coming from the front or maybe clutch.
    It gets more noticeable every time I slow down to stop and it disappears.
    Mechanic doesn't know what's causing it but thinks it could be diff related.
    I wonder if it could be clutch related. My clutch has a common problem, there is a washer in it that makes a noise when I start first thing in the morning, then it goes away. This apparently is common and nothing to worry about, but the winning noise I hear as I stop it's getting me worried.
    Near Seven Hills, Sydney
    Drop the diff oil, see if there is enough volume there, and that it isn't full of glitter or water. Fresh oil is cheap!
    Dual mass Flywheel springs vibrating?
    Mar 2010
    Cairns
    Quote Originally Posted by isuzutoo-eh View Post
    Mechanic changed the oil.
    I asked to check the diff, but i was told that it could only be checked through the drain plug and therefore not much could be seen. (the diff pan couldn't be opened !!!!!!?????)
    Mar 2010
    Cairns
    There's no vibration there. The clutch feels fine.
    May 2008
    Horsley Park, Sydney
    I just replaced my back diff in our 06 Defender because of a whining noise - really apparent when slowing down. I couldn't see anything wrong with the diff I removed, but the noise disappeared instantly. The noise started ages ago and I didn't think it serious, but for peace of mind.
    This is in a vehicle with 95,000kms on the clock and had 4 oil changed in the diff since new.
    Erich
    Mar 2010
    Cairns
    Quote Originally Posted by Bundalene View Post
    Erich
    It sounds like the same problem as mine. Mine has 140.000 Km.
    If it's the Diff (as the mechanic also suggested) I was thinking of replacing it with a stronger unit.
    Again the mechanic suggested putting a rear diff at the front because they are stronger.
    I thought of putting a Salisbury but they don't seem to make them for the front diffs.
    Any thoughts ......???????
