Thread: Series Transfer Case Oil Leak (Surprise!)
    Aug 2010
    Glebe
    G'day all,
    So my 1978 SIII 88" is finally on the road and rego'd after two years of rust repairs, swearing and steering rebuilds. Big thanks to the boys down at Land Vehicle Spares.
    Anyway, having not had it registered, I'd never driven it more than a few hundred metres. After picking it up from Silverdale, I drove home, stopping to check for leaks after about 30 mins of driving. Sure enough, a trickle of nice clear EP90 was dripping off the bottom of the transfer case.
    I opened up the centre seat box, and oil was pooling around the cover closest to the drivers seat(see photo). I pressed the plate and beads of oil were being sucked in and out along the edge, so it was definitely not sealed properly. I replaced the gasket and sealed it with loctite, drove around a bit to warm it up, no leak on arrival back home. Next day I drove it to work, no leak. Drove home, leaking again.
    My question is, is it just this seal, or is there a bigger issue afoot that's causing pressure to build up in the transfer? I suspect my transfer case output oil seal is gone (based on the oil on the handbrake housing, though this appears to be a very slow leak, I've never seen any oil drip off it). I also have a sneaking suspicion that the seal from the gearbox to the transfer case may be gone, allowing oil to migrate from the gear box to the transfer. Will replacing this seal stop a build up of pressure in the transfer case, or should I install a breather somewhere on it?
    Aleksei
    I am here: [ame="http://maps.google.com/maps'll=-33.768395,151.067068"]Google Maps[/ame]
    Aug 2010
    Glebe
    Photos
    I am here: [ame="http://maps.google.com/maps'll=-33.767953,151.066826"]Google Maps[/ame]
    There is already a breather. Look at the cover plate held by two screws on top of the highest point of the gearbox. It has a small hole in it that is the breather for both the gearbox and transfer case. If you remove the plate, you can see a passage from the cavity beneath this backwards into the transfer case. Both these breather holes must be clear.
    While it is possible there is a blocked breather, I think that the cover plate failing to seal is more likely - rotation of the output assembly "jets" oil against this cover, so if there is any chance of a leak, it will show up. There are several possible causes for this cover leaking.
    Cover plate not flat.
    Bolt threads bottoming out, possibly due to either wrong/no washers, wrong bolts or gasket too thin.
    Coming loose due to stripped threads
    Surfaces were not clean and dry when sealant was applied.
    Hope this helps,
    Aug 2010
    Glebe
    Thanks John,
    I'll take the top cover off and check the breather(s). Just to confirm, it's the cover in the photo?
    There appears to be a weld along the edge of the transfer case which might be creating a small gap, I'll try filing that down, re-sealing it and will report back.
    Aleksei
    I am here: [ame="http://maps.google.com/maps'll=-33.768115,151.066861"]Google Maps[/ame]
    Quote Originally Posted by Krafty_Lucas View Post
    Thanks John,
    Yes. Strategically located so as to be difficult to get at - you probably need to remove the transmission tunnel, which means removing the floor.
