Results 1 to 10 of 13
Thread: Rave CD pdf acrobat 4 wont work on tablet!
    Jul 2010
    Hunter Valley NSW
    Hi
    I purchased the rave cd here on aulro for D2 Td5. Works only in acrobat reader 4 not the current readerX which I can manage with but I'd like to use in on my acer tablet pc but cannot operate reader4.
    Can I convert acrobat4 to 10?? Is there some way I can use it on my tablet?
    Help Thanks
    It'sNotWorthComplaining! Guest
    There is a program called freerave. this unlocks the encryption and security allows editing of rave and allows it to open on any pdf reader and allows it to work on linux and macs as well as windows
    Mar 2011
    Burpengary, QLD
    Quote Originally Posted by It'sNotWorthComplaining! View Post
    Any idea where we can get this from? It would be much nicer to be able to open the PDF files directly from the installed reader...
    A google search finds nought but free rave dance parties...
    Feb 2011
    Brunswick, Victoria
    You need to work on your google-fu
    From googling on freerave i've found that:
    The website (Landrovertec.com) that was hosting FreeRave died at some point in 2010. The only hope is that someone who has the freerave_1.36.rar file is kind enough to make it available to those of us who missed out.
    Apparently "Free Rave" is a patched version of Acrobat 4 which replaces the Acrobat folder on the Rave disc image. Once installed the "new" version of Acrobat allows the user to unlock the pdf's which removes the encryption. Once this is done you are free to open the pdf's with any application that will read them...
    Guys I have the program to do it, but I cant seem to be able to upload the file folder with it's contents as an attachment.
    If incisor allows me to email it to him and he is able to post it in downloads etc, without causing this site any grief then I am prepared to share it with in the forum to members.
    If not then pm your email addresses and I email it to you.
    Ps This is how it is done.
    Land Rover, Rover, MG, Mini, v1.36 2008
    RAVE Free PDF Files.
    1) Copy the whole content of any RAVE CD to a temp directory i.e. C:\RAVETEMP\
    2) Delete the directory Acrobat4 from C:\RAVETEMP\
    3) Extract the content of the file to C:\RAVETEMP\ replacing the erased directory.
    4) Start Rave normally from C:\RAVETEMP\Rave.exe or C:\RAVETEMP\TData.exe
    5) You'll see 2 padlock icons (if the Tool Bar does not show up press F9):
    a) Padlock Blue: Available if current file has protection, allows to remove
    it and save.
    b) Padlock Yellow: Only available when browsing the initial file (Welcome.pdf or Rave-rc.pdf)
    This action will process the whole RAVE structure. The process takes about 10 minutes
    every 300 Megs, it cannot be stopped, it is cpu intensive, Acrobat's screen might not
    be refreshed correctly while running. The file ProcFiles.log keeps record of the process
    After the process the PDF files can be viewed with a regular Acrobat Reader even on MAC.
    LRTA 2008
    Quote Originally Posted by DavidB View Post
    Hi all,
    Hope this helps.
    Dave.
    Ah you up loaded it as a zip file, mine was unzipped and in a folder, the folder would not upload. I didn't think about re cpmpression.
    nispa Guest
    Talking You save my car!
    Hi all,
    Hope this helps.
    Dave.
    Thank you very much! I had a t4, but something went wrong and now it does not work anymore... But thanks to you i can use my rave cd again!
    Thank you from Italy!
    Leendert Guest
    Is this program still available, I can't find it?
    Regards Leendert
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    all the rave cd's in the shop have been freeraved for years
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    all the rave cds in the shop have been free raved for years
    it and save.
    LRTA 2008
