Results 1 to 8 of 8
Thread: TD5 Oil Cooler "coolant" leak
    Dec 2010
    Brisbane Bayside
    Anyone had a coolant leak btw the oil cooler housing and the engine block (TD5) it's a metal crush type gasket. When I say leak I mean a weep once a week. No coolant in oil,, no oil in coolant, straight out leak btw two housings???
    BIG O
    03 D2 TD5 AUTO
    99 D2 TD5 AUTO ACE
    94 D1 TDI 3 DOOR (GONE)
    Dec 2010
    Brisbane Bayside
    Anyone????....
    99.87 MB
    Your post doesn't make sense.
    Slunnie
    Oct 2008
    Heart in the Deep Nth of FNQ,Body in the Deep Nth of Brisneyland
    Big O, No I haven't. Needed to replace the heat exchanger matrix itself, but no leak in the gasket.
    It was in pretty poor shape, though. Wouldn't have lasted another year I think.
    And, yes, removing and replacing the assembly is a PITA!
    Cheers, Dave.
    Dec 2010
    Brisbane Bayside
    I WILL TAKE THAT AS A NO.
    ..Its a TD5, it has an engine oil cooler that is cooled by coolant from the radiator..The cooler bolts to the side off engine block. It has a metal gasket between the two of them. I have coolant leaking from between the oil cooler and the engine block. Anyone else experience this ??.
    Dec 2010
    Brisbane Bayside
    Sorry,, thanks DAVE four YOUR reply.
    Mar 2010
    Patagonia
    It has happened to me. Not difficult to fix only very labour intensive. Good opportunity to do a number of other things since turbo will have to come off and exhaust manifold possibly too.
    When installing the new gaskets use high temp anaerobic gasket sealant. Also keep in mind you'll be dealing with alloy castings so torque by the book!
    Rgds
    Matt
    Apr 2007
    MUSWELLBROOK
    I have had mine of and resealed but only to check for corrosion as I have seen eone of these corroded through. Not a hard job but time consuming to get to.
