Page 1 of 6 123 ... LastLast
Results 1 to 10 of 54
Thread: Do we need an Evoque section?
    If so, where?
    If we put it in the Pinnacles under Range Rover, then the RRS should be moved from D3/D4/RRS.
    Should it go under Freelander?
    Mar 2009
    Soon to be Hobart
    I'd put it under freelander..... they're kind of in the same category but at different pricing points...
    Is it the same chassis as the freelander or similar running gear?
    Kenya
    D3/RRS share a heck of a lot of parts and problems, so it makes sense having them together. How related are Evoque and Freelander2? If as closely related as D3 and RRS then put them together. However how different is a Disco1 from early RRC, mechanically speaking?
    Sep 2006
    Northern Beaches
    What is an Evoque?
    Jeff
    Aug 2010
    Sunbury, VIC
    Yep, as you have mentioned, you have 2 options - if the RRS is to stay in the D3/D4 section, then the Evoque should be in the Freelander section. If you put the Evoque in the Range Rover section, then so should the RRS. In my humble opinion, they should both be in the Range Rover section.
    Just my 2 cents.
    Cheers - Gav
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    Quote Originally Posted by Jeff View Post
    What is an Evoque?
    Jeff
    dunno but an evoke is to call up , provoke, cause to appear, cant find an evoque in my dictionary......
    Dec 2009
    Tyrendarra Vic (South West Vic )
    My 2c worth D3/D4/RRS as is & Evoque with Freelander
    Gary
    Nov 2008
    about the only things same between the evoque and fl2 is the lower part of the chassie, rear diff, and if im correct the center bearing for the tail sharft is the same, (but the sharft is diffrent)
    but other then that there all different, different motors, boxes, electrics are allso different with 19new harness added for the evoque, they dont even have the same landrover badge
    so make of it as you want,, the to cars are very very different not just buy looks, i think it should just go in with range rover,
    Jun 2008
    McMinns Lagoon NT
    Did your question evoke as much discussion as you thought it might Ron?
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Near Seven Hills, Sydney
    Give the Evoque its own spot. It's a whole new model, otherwise Series, 90/110/130 and Isuzu sections should be lumped together as they all have more in common than the Evoque and Freebie or L322
