I wish I was there.
My head light reflectors have a small 1/8 hole drilled in the bottom of them to drain the water from the lowest part of the lens.
I killed a reflector early in the piece by leaving the water/ mud in the head light for alittle while and that is enough to lift the reflective surface.
( check my avatar)
Garry you are braver than me...........I will never get used to the backend lifting and a front wheel dropping down a hole.........I still remember the wallaroo quarry decent..
Whats with the spare tyre ?
Your 101s motor is OK the couple of times I drove it,,,,,,freeing up flow by going from a tee piece to a Y piece before the muffler on mine made a slight improvement ......I love the 101s motor on a off road climb and its great flexible rev range you can trickle along at 1000 rpm all day or venture into 5000 rpm plus if needed......long live 101 landrovers.
May be we should plan a run to the Brindabellas??????? 101 landy style ????
					 Struggling find time at the moment.
 Struggling find time at the moment. Like the idea of a 101 hook up somewhere.
