Results 1 to 10 of 14
Thread: tyre and rims for 1994 110 defender
    James Neilsen Guest
    Hi
    I have a 1994 110 defender and need to get a better beach tyre package
    Can anyone let me know the options and the actual stud pattern?
    I can get a hold of a set of 16*8 of a new defender that is being wrecked, will they fit my older version
    Also I am on the gold coast if anyone has a nice wide set for the beach for sale
    Hope someone can help
    James
    Feb 2005
    the current model wheels will fit, you might need matching nuts
    how wide do you want to go?? i have not had any problems with 235/85/16's which are standard either on the beach or in the desert.......
    i run disco rims with 235/85/16 BFG/MT's fitted
    Melb. Vic.
    G'day James,
    Welcome to the forum. Feel free to post up some pics of your Def. and post in the Introductions section a quick hello.
    From memory the standard rims are still only 7inches (alloy) and 6.5 for steel on the newer defenders. (after 1999 - Td5 and 2006 - Puma models). They will fit your vehicle.
    If you have original steel rims they will be 6 inch.
    Lots of options - do a search here for "tyres" and you should find approx 10,478 threads.
    In short I would stick with 16 inch. Steel (and alloy) wheels off Discovery 1 (1990 to 98) will also fit as will Range Rover (pre 1994).
    Paul
    Tassie/Perth
    I'll agree with above. The standard steel rims with 235/85R16s will be fine. I also reckon a good set of ATs or even MTs will be fine as well. It is ALL in the tyre pressures.....
    South East Tasmania
    I have 235-85-16 in 1988 RR rims fitted with Maxxis Backshot tyres and is very good set-up for all terrains.
    Feb 2011
    Traveling Aus
    +1 on the tyre pressure
    give 12psi a crack.
    that's what i use on my 130 on soft sand and dunes but a mate uses the same on his 110. both run 235/85's
    it's all trial and error and also depends on what tyres your running on the car and how you drive.
    but i guess you must be up for new tyres anyway?
    you could get those rims from the wreck and put 255/85's on her without many problems.
    you will loose some power however.
    and x2 on the pics
    SW of Geelong
    Quote Originally Posted by Benz View Post
    give 12psi a crack. ........
    that's what i use on my 130 on soft sand and dunes but a mate uses the same on his 110. both run 235/85's..............
    put 255/85's on her without many problems, you will loose some power however..........
    Quote Originally Posted by cewilson View Post
    ......... It is ALL in the tyre pressures.....
    I agree, tyre pressure is way more important on sand than tyre width. I've done a lot of sand driving on various tyres and treads, 750x16, 235/85/16, 255/85/16, A/T's, M/T's and there's next to no performance difference between them, as long as you drop the pressure for the conditions.
    Cheers, Murray
    '88 County Isuzu 4Bd1 Turbo Intercooled, '96 Defender 130 CC VNT
    '85 Isuzu 120 Trayback, '72 SIIA SWB Diesel Soft Top
    '56 SI Ute Cab
    Jul 2007
    Defender stud pattern is unchanged going back to the start of landrover. At some stage they changed the thread to metric but that is about it. It is not until the Disco 2 and RR P38 that they changed on landrover vehicles other than the Defender to a smaller diameter on the pattern. DOn't know about the Freelander.
    You need to be aware that steel wheels and alloy wheels use different nuts.
    Also the wheels on your Defender if original will be for use with tubed tyres and are 5.5" wide.
    When you start going to bigger tyres and wider wheels you need to ensure that the tyres will not rub on bodywork or suspension/steering components. I am sure that if you do a search or wait a little bit someone will come along and tell you the max size tyre that can fit under a Defender without a lift or guard modifications.
    I run 7.50 x 16 and did the Simpson and other outback tracks that had plenty of sand and they managed just fine. Air pressures is the secret as others have pointed out. And for sand the less aggressive a pattern the better so ATs should be fine. The more aggressive tyres will break the crust on the sand then it will be easier to sink into it.
    numpty's Avatar
    numpty is offline TopicToaster Silver Subscriber
    Nundle
    Quote Originally Posted by slug_burner View Post
    Wheel nuts for the alloy wheels can be used with the steels but not vice versa.
    I too have used 750/16's on Simpson and Fraser with no issue and current 235/16's on Madigan Crossing also with no issue (apart from the odd puncture) agree with comments above, tyre pressure is the key.
    Numpty
    REMLR No 143
    Apr 2010
    Connolly, WA
    As all replied, the stud patern (PCD) has been 5 x 6.5" for the last 62 odd years and the alloys are definitely 7" wide.
    If you do get alloys off the wrecked one, make sure the nuts, lock nuts and their key comes with otherwise you'll have to get a complete set from the stealers for the price of a small county's defence budget...
    Just something to keep in mind is that if you come accross steel wheels in a 5 stud patern, make sure they're not L/Cruiser because they use a 5.5" PCD.
