Page 1 of 7 123 ... LastLast
Results 1 to 10 of 63
Thread: Leaf spring question
    Oct 2010
    Yarra Valley Victoria
    Hi All.
    I am in the process of removing the rear springs from Mary my
    2A 88 for clean up. I was thinking of removing 1 or 2 leafs as I don't plan to carry much weight and I would like the ride a little softer, has anyone else done this and if so was it successful? I have cleaned up the front springs and the difference is amazing! I
    Cheers Simon
    Narrogin WA
    Yes. Do a search for "Parabolic Springs" on the S3 forum and see what Isuzurover did to his standard springs,
    Cheers Charlie
    WA
    Simon, If you have the OE 88" rears (11 leaves x 4ish mm ) then I wouldn't remove any. They are already ~160 lb/in which is quite soft. If you have LWB or aftermarket springs, then the OE 11 leafers are probably the best option.
    Oct 2010
    Thanks Isuzurover.
    I will check to see what I have and follow your advise, if they are OE I will clean them up as was done for the front and hope the ride improves
    Cheers Simon
    WA
    Quote Originally Posted by VK3UTE View Post
    Thanks Isuzurover.
    Cheers Simon
    Just make sure they aren't aftermarket 11 x 5mm leaves. In which case they will be VERY stiff and you can remove plenty of leaves.
    Many 88's were fitted with 109" springs, so the same applies.
    Oct 2010
    Pulled the rear springs apart today and they are all 5mm except the main leaf which is 6mm.
    From that I assume they are the aftermarket ones so I cleaned and painted them and will assemble them with 3 or 4 leafs removed and see how they go. That might explain why the ride was so bad
    Oct 2010
    All back together, left out 4 leafs which kept the lengths equally spaced. What a difference when you hit a bump now the back wheels stay on the ground and you don't hit your head on the roof!
    It does feel a little too soft but I will give her a run like this and see how she goes. Thanks for the advise
    Front leafs before
    And after
    Cheers Simon
    East-South-East Girt-By-Sea
    1.20 MB
    Did you put some moly grease between the leaves, makes a great deal of difference.
    Oct 2010
    I used anti-seize paste which I hope will do the job ok.
    Oct 2010
    Articulation
    I got a little board in the shed today, I've always wondered how much articulation a standard 2a has
    Not bad for an old girl. 430mm, nothing special done other than a clean, lube and a few leafs removed from the rear. She still has axle straps fitted too.
    Then I got thinking how much better would a Defender be
    Well
    520mm not that much more really...
    Would be interesting to see how much more a 2a military would have
    Pretty cool I reckon
    Cheers Simon
