 Originally Posted by
ADMIRAL
				Hi Andrew,
An observation.  I have no personal experience with the replacement of this particular bush with urethane.  However, in general the urethane bushes are stiffer with less flex.  Put them into a situation where flex is required and often, and they will crack.  Make the bush stronger, and the flex is reduced.  This may enable the bush to last longer, but reduced flex may not be a good thing, and could have negative wheel travel and handling impacts.
Others will have a point of view, and you can also check out the UK sites.
