Results 1 to 3 of 3
Thread: cable or copper, do i need to upgrade my ISP
    Feb 2005
    have not check on my account for years but it looks like i'm on this package which does not mean much to me
    Package Type: Ultimate ADSL2+ with VOIP /50GB @ $49.99/month
    we like to rent movies online how do we speed it up? the kids are also mentioning our internet is slow.......it currently can take an 1hr + to download a rental and this is with a cable connect between modem and apple tv box....
    we run on copper from the exchange......
    is it our modem which is the original one from eight years ago?
    oh the other thing is is i am buggered if i can work out haw to set up the security on the modem....
    look forward toy our suggestions...
    Jan 2009
    Samford
    From what I can work out you connect to the Sandgate exchange and are about 3.9km away (via the cabling) which is getting a little on the high side for ADSL2+. The further you go, the quicker ADSL2+ speeds drop off compared to ADSL and cable. In theory, you're going to get you around 5Mbps on ADSL2+, possibly a bit less in reality. You should get better speed on cable. You already have the cable to your house, so that will save you on installation but you'll need to buy another modem. You may find a plan that will include a modem though. Is your current modem ADSL2+ capable? If not you'd be up for a new modem either way you go.
    Really, at the sort of speeds we're talking, your average residential user isn't going to be too concerned. It will more often than not come down to the cost/package. Broadband Choice is a good place to start comparing plans.
    Jul 2011
    Yarrawonga, Vic
    If you lift a telephone while your downloading something do you hear static on the line. Is the static gone when the modem is turned off.
    If so you have a filtering issue or a faulty line and this will affect your speed.
    do a speed check at http://speedtest.net
    take note of ping time, download & upload speed,
    unplug all your phones / fax / filters everything else & just plug the modem itself in and run speediest again
    If its noticeably better you have a fault.
    You should be getting about 10 -12 mbps
    Telstra only guarantees 1.5 mbps & most likely won't fix , at least when I worked for them. There is not too many techs in Telstra that are good on ADSL faults in the short time allocated per job, its not worth the time with the pressure from above for quantity rather than quality.
    if you have the option Your better off on cable, you should get a free modem with the migration to a cable plan.
    With the UHSI modems we were installing it was typical to get btwn 80 - 110 mbps rather than the normal 30mbps cable modems.
