                                                30th January 2012, 09:34 PM
			army springs
					hey guys, does anyone know if the military springs in a series 2a are standard height or raised, or is the difference in height only from the military shackles. thanks heaps guys
                                                30th January 2012, 09:38 PM
					Pretty sure the height comes primarily from the shackles.
 Although the heavy rating of the springs would keep them sitting up too.
                                                30th January 2012, 10:47 PM
					The extra height comes from the shackles and extended spring hangers.
 The front springs are (should be) standard 109" 11-leaf fronts.
 The rear springs should be "heavy duty" 8-leaf springs (7.1 mm thick leaves).
 You will get a lot of extra wheel travel if you remove 2-leaves from each pack. Search for my threads on modifying springs.
                                                30th January 2012, 10:55 PM
                                                #4
					Ok thanks heaps guys, I thought that was the case, much appreciated
