Results 1 to 10 of 16
Thread: Tyre selection help
    chook73 Guest
    Tyre selection help
    So I am now in the market for new Tyres. I have a set of bfg km2 which have been great however slightly undersized from the size quoted and also were slow to get a hold of.
    So the current selection list is
    Another set of km2 however I might have to wait until they are in stock and will be at least an inch under spec.
    Mickey thompson mtz
    Cooper stt
    All are 8 ply side wall but the only one in stock are the cooper which is really the only reason I am considering them.
    All seem to have good and bad feedback so what really tells them apart.
    If it matters I am after 315/75r16
    Iain
    in the wild New England, NSW
    I haven't heard very much positive about coopers but 8 ply sidealls may be better -
    tyres in use around here seem to be BFGs, and are what I have been happy with for years
    ... pricewise I will be taking a look at Maxxis Bighorns next but I don't know if the size you want is available in them
    Central Coast NSW
    Hey Iain,
    I have been looking into tyres/wheels for my SVX.
    After many months of deliberation I am about to order -
    16 x 8 Dynamic steel rims with neutral offset
    Mickey Thompson MTZ's 285 x 75 x 16 (33's).
    This combination should just fit under the guards, not reduce any steering lock or cause any rubbing to suspension components on full articulation or not.
    Only time will tell or possible another member that has this set up.
    Central Coast NSW
    Quote Originally Posted by chook73 View Post
    Iain
    Iain,
    What wheels are you going to use and what off set ?
    Crabtree, Tas
    Can only comment on the Mickey T's in 285 75 R16 as mine are fitted to a Disco (with Dynamic -25 8" rims) with arches, body and spring lift.
    For a mud terrain, they seem to be exhibiting pretty good on road manners (good levels of grip in the wet and greasy stuff and feels direct over bumps and in corners) apart from the roar at highway speeds and have been wearing really well considering the kays I do and the thrashing they've been subjected to.
    I would recommend and wait for them, and will be getting them again when these ones wear out.
    chook73 Guest
    Quote Originally Posted by Drover View Post
    Iain,
    I am fitting a set of Tibus portals so the wheel is a hutchinson beadlock for the Pinzgauer with a 65mm offset Hutchinson rims - Pinzgauer TD
    I prefer these over the Mercedes G as they are a hell of a lot cheaper (about $550 per rim as compared with $1300 for the G rim) and they have the bolts that fit trim as opposed to sticking out.
    Drover if you are interested in a set of steel rims with 0 offset I have a set of 6 King rims about 10 months old that are in pretty good condition (only one small dint in one rim and it has not upset the balance). I have a friend that is keen for the 265/75 BFG but as he has a Hilux he doesnt need the rims.
    Should be available in about 8 weeks or so and I can do a good price.
    Central Coast NSW
    PM sent.
    Nov 2008
    Illawarra
    I have 255/85 r16 bighorns and the y are far better than the 235 cooper/bfg at combo they replaced. Dont knowabout mickey or the newer coopers.
    Cant wait to see the portals on an oz regoed car
    Near Seven Hills, Sydney
    If you're going portals, step up to 36s+, or it'll look silly. I think Brendan has his engineered for 37s or thereabouts but runs an inch or so smaller.
    Looking forward to seeing it!
    Mar 2010
    Mudgee-ish
    So.....you won't be taking it to go shopping at Westfields. If you contact the RTA they will give you a map of all the low bridges in NSW.
